JD 2 row corn planter
   / JD 2 row corn planter #1
DeereHunter
I have an old JD 2 row corn planter that I'm trying to find info on,
1st, is there a name/model plate somehere on it?
2nd if so, where is this?
many thnx in advance
   / JD 2 row corn planter #2
Does it look like this??
If so, then it is a 290 model. Otherwise could be a 246 if it is older model.
   / JD 2 row corn planter #5
I have one of these(290) that I plan to use for the first time this spring. Have you used one before and do you have any suggestions or tricks? I also need to match seed to the plates that I have.
TS
   / JD 2 row corn planter #6
:welcome" smithky2
Check with your seed dealer for the right plates, or your Deere dealer parts guys for some help.
And stay tuned for help from TBN too.
What plate does your seed ask for?
   / JD 2 row corn planter #7
Right now all my seed (corn & beans), planter and plates are at the farm. While on the net I found TBN joined and was surprised to get the quick respones so I'm unprepared and thank you for the quick reply! Obviously I'm not a farmer (using a JD 290) but a hunter with some family farm background that has 30 acres of plantable ground that I plant in food plots and this year I wanted to plant some corn and beans. Any help is appreciated. I'm also a rookie forum user!
TS
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
