JD 1950's tractors
   / JD 1950's tractors #1
John Baldwin
jd 430 U
Interested in JD 40.420.430, and implements they operate
   / JD 1950's tractors #4
This information is from Tractor Data
John Deere 430 Power
Drawbar (claimed): 27.1 hp [20.2 kW]
PTO (claimed): 29.2 hp [21.8 kW]
Drawbar (tested): 26.15 hp [19.5 kW]
Belt (tested): 28.31 hp [21.1 kW]
John Deere 420 Power:
Drawbar (claimed): 20.31 hp [15.1 kW]
Belt (claimed): 24.83 hp [18.5 kW]
John Deere 40 Power:
Drawbar (claimed): 16.77 hp [12.5 kW]
Belt (claimed): 21.13 hp [15.8 kW]
Drawbar (tested): 22.9 hp [17.1 kW]
Belt (tested): 25.2 hp [18.8 kW]
This information i from searches on the net.
As you can see from above there is almost 10 horse power difference between a JD 40 and aJD 430. So that will make some difference. All three have the same PTO that has an RPM of 540. So only difference there is Horse power at PTO.
General rule of thumb is: Bush hog is 5 horse power per foot. So JD 40 would run a 4 foot, a 420 would run a 4 foot and a 430 could run a 5 foot.
Plows: 1-1.5 hp per inch as a guide. So a two bottom 14 plow would work on the JD 430. The JD 40 co0uld pull a 1 bottom 16? while the 430 could pull 2 bottom 12?
Disk: all three should pull a 6 to 7 pull behind.
Soil condition is a big consideration in all the tractors.
I hope this is something likec what you wanted to kniow.
In 1951 we farmed a 100 acre farm with a CA Allis Chalmers. Which had the following power
Allis Chalmers CA Power:
Drawbar (claimed): 18 hp [13.4 kW]
PTO (claimed): 23 hp [17.2 kW]
Drawbar (tested): 22.97 hp [17.1 kW]
Belt (tested): 25.96 hp [19.4 kW]
Don
   / JD 1950's tractors #5
a jd 40 will run a 5' hog fine.. look at belt hp. not drawbar.
soundguy
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2012 Nissan NV2500HD Cargo Van (A51692)
2012 Nissan...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
