jd 1910 airseeding carts
   / jd 1910 airseeding carts #1
wazza
has anyone had water getting into distribution systems.??
   / jd 1910 airseeding carts #2
Welcome, and you are probably thinking you are being ignored. Truth of the matter is likely you are, because likely no-one here is using the cart you speak of and therefore do not have a problem with water getting into the system in the cart they do not have. The question you have is specific, and not likely to pertain to this forum, or its members, which is mostly about compact utility tractors.
Hope we are not coming across as being rude, but you need to seek a different forum for the answer or head back to your Deere dealer.
Sorry.
What tractor do you pull that 'cart' with? Any thoughts as to why water would be getting into the distributuion systems in it?
   / jd 1910 airseeding carts #3
He probably pulls the planting cart with a large row crop tractor like a JD 8400 or so. Big ag equipment that none of us have here. I see it at work but I am not a tech so I can't answer anything techinical about this air seeder.
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
LandPride RCF2072 (A50120)
LandPride RCF2072...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
New Holland TN60A (A50120)
New Holland TN60A...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
