JD 185 Hydro Start/Run problems
   / JD 185 Hydro Start/Run problems #1
hosickjg
Ontario
John Deere 185 Hydro
I'm having problems with my 1989 JD 185 Hydro. Here's the symptoms:
Starting Problems:
-The only way to start it is to pull the throttle/chock on full and let it turn over 30 or so times until it floods
-Then put the throttle down to a dead idle and it will sometimes then start at a dead idle.
-Then I have to work the throttle up SLOWLY until it gets to operating speed.
-If I move the throttle even a tiny bit to fast it dies out and I have to go through the starting steps again.
-Once up to operating RPM it runs great and can be worked in tall grass or with the blower on with no issues
Things done:
-I have taken apart the carb and cleaned it with carb cleaner and compressed air. It was very clean already and doing so didn't change anything.
-I've checked the spark and it appears blue and healthy
-Compression is fine
Suggestions?
Common issues with these tractors that gave the same result?
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A55788)
2012 Peterbilt 382...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
378467 (A51572)
378467 (A51572)
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
Toro Mower (A50324)
Toro Mower (A50324)
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
