JD 160
/ JD 160 #1
tude
Knoxville PA
John Deere A
Well after 35 years the bolts (JD calls them cap screws) that attach the blades to the spindles have rounded heads. You would think I could get a couple more years use out of them. My local JD charged $2 for the two replacement cap screws. I was able to use an extractor to loosen the bolts without removing the deck.
/ JD 160 #2
Not a bad price in today's market. In fact, that's down-right cheap. I think the complete name is Socket Head Cap Screws. These have a round head with a female hex hole. An "Alen Wrench" or "Alen Socket" is used to install and remove. It's a good idea to put a daub of grease in the hole to keep the hole from rusting. They used to have caps you could install to keep them clean, but I haven't seen those in years.
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
PORTAPOTTY (A68842)
PORTAPOTTY (A68842)
2024 Texoma 16ft. T/A Equipment Trailer (A68183)
2024 Texoma 16ft...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
