JD 160
   / JD 160 #1
tude
Knoxville PA
John Deere A
Well after 35 years the bolts (JD calls them cap screws) that attach the blades to the spindles have rounded heads. You would think I could get a couple more years use out of them. My local JD charged $2 for the two replacement cap screws. I was able to use an extractor to loosen the bolts without removing the deck.
   / JD 160 #2
Not a bad price in today's market. In fact, that's down-right cheap. I think the complete name is Socket Head Cap Screws. These have a round head with a female hex hole. An "Alen Wrench" or "Alen Socket" is used to install and remove. It's a good idea to put a daub of grease in the hole to keep the hole from rusting. They used to have caps you could install to keep them clean, but I haven't seen those in years.
250 GALLON POLY TOTE W/ CAGE (A50460)
250 GALLON POLY...
2022 Load Trail Trailer, VIN # 4ZEUT1827N1269100 (A48836)
2022 Load Trail...
12ft Stainless Steel Livestock Panel (A48837)
12ft Stainless...
2003 Ford F-350 Pickup Truck, VIN # 1FDWW36P63EC81092 (A48836)
2003 Ford F-350...
20 Gallon Air Compressor (A50860)
20 Gallon Air...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
