JD 160 (pre 80) will not start
   / JD 160 (pre 80) will not start #1
jgahugg
JD 160
At the end of the season last year, my ignition switch went bad and I had to replace the switch. Now the mower will not start. The gas is good, battery is good, mower has spark, the fan turns, but the engine will not crack. Any suggestions?
   / JD 160 (pre 80) will not start #2
Do you know if you are getting voltage at the starter? It could be the solenoid.
   / JD 160 (pre 80) will not start #3
I had a similar problem last year after doing a lot of work with the tractor. When I went to have the unit serviced the mechanic could not get a decent compression reading. I ended up buying a second hand motor on E-Bay and will have the original motor re-built at a later time. I really like the 165 and will keep rebuilding it as long as I can get parts.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
