JD 160 (pre 80) will not start
   / JD 160 (pre 80) will not start #1
jgahugg
JD 160
At the end of the season last year, my ignition switch went bad and I had to replace the switch. Now the mower will not start. The gas is good, battery is good, mower has spark, the fan turns, but the engine will not crack. Any suggestions?
   / JD 160 (pre 80) will not start #2
Do you know if you are getting voltage at the starter? It could be the solenoid.
   / JD 160 (pre 80) will not start #3
I had a similar problem last year after doing a lot of work with the tractor. When I went to have the unit serviced the mechanic could not get a decent compression reading. I ended up buying a second hand motor on E-Bay and will have the original motor re-built at a later time. I really like the 165 and will keep rebuilding it as long as I can get parts.
40ft 6-Door Shipping Container (A52377)
40ft 6-Door...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
