Buying Advice JD 1530 Odd Bucket
   / JD 1530 Odd Bucket #1
newbiefarmer
Savannah
None Yet
Hi, I am new to tractors - we mainly grow things in greenhouses but decided to expand outside to a couple of acres of vegetable cultivation, and also need something to mow a couple acres of grass.
I found an older John Deer 1530 that was used on a horse farm mainly for hay moving. It runs pretty well, and my only concern is it has kind of an odd bucket on it - it is smaller and also only has one ram for tilt.
Two questions:
1) Does this bucket suck?
2) If so, can it be replaced with a larger one without a major retrofit (e.g. new rams)
Here's an image
   / JD 1530 Odd Bucket #2
The loader on the 1530 is one of JD's cheaper,lighter built loaders. IIRC it has no down pressure on boom cylinders. You could "blacksmith" a larger bucket on it.
Thanks for the quick response - I will check on the no down pressure on boom - in the little time i have on equipment with a loader, it seems like most of the time I am using tilt to apply downpressure are there other impacts to this design?
Also, is there a model of loader I could retrofit easily that is widely available used?
Thx
   / JD 1530 Odd Bucket #4
Your loader is a model 37. In JD loaders models 48,145,146,175 come to mind
   / JD 1530 Odd Bucket #5
That is not at all odd to me.
That is what most all loader buckets were many years ago.
   / JD 1530 Odd Bucket #6
From your picture, the boom cylinders are single action, so no down pressure. :thumbdown:
   / JD 1530 Odd Bucket #7
Hey is this loader for sale?
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
206320 (A57192)
206320 (A57192)
PALLET OF CULTIVATOR PARTS (A52708)
PALLET OF...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
