JD 14T keeps breaking flywheel shear bolts
   / JD 14T keeps breaking flywheel shear bolts #1
angel in ME
We had an upper hay dog spring break, changed all 3 springs and now the flywheel shear bolt keeps breaking, which I think if I remember right we broke one of these the other day when the spring to the upper hay dog broke. It's allmost like the needles do not return all the way home.. not sure what is going on???
Any help greatly appreciated
Angel
   / JD 14T keeps breaking flywheel shear bolts #2
Are the knives sharp. Is the clearance correct on the knives? Does slowing down help any? Is the hay damp/wet when it shears? Are the ram guides in good condition? Ken Sweet
   / JD 14T keeps breaking flywheel shear bolts #3
The lower plunger stops are not retracting out of the bale case because the needles are not completely at home position. It's out of time or the needle position lever and bar is bent, broken or its spring is not strong enough. The knotter drive chain may have jumped a tooth when the first jolt hit.
   / JD 14T keeps breaking flywheel shear bolts #4
what is the needle position lever? My baler has the same problem.
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2005 JLG Skytrack 8042 (A47477)
2005 JLG Skytrack...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
