JD 145 battery drainage while sitting in between mowing cycles
   / JD 145 battery drainage while sitting in between mowing cycles #1
nickel plate
CA
2002 New Holland TC40S
I have a John Deere 145 Automatic 100 Series with a 22 hp Briggs and Stratton with 65 hours on the clock purchased new in 2005 from our local JD dealer. The problem is that the original battery goes practically dead enough not to start on the following lawn cutting, usually once a week or so during the growing season. A five or ten minute charge fires it up with no other issues noted. If I have to shut it off during a mow it will fire right back up again. It does get quite a bit of corrosion powder build up on both poles, the positive pole creates more and there is always a surface film of acid on the top of the battery. I have on several occassions removed the original battery and +- cables for thorough cleaning only to experience the same thing again a few weeks later. Any ideas as to what causes this?
   / JD 145 battery drainage while sitting in between mowing cycles #2
I agree with k7LN, you either have a bad battery or a low voltage short somewhere. Either have it tested or disconnect the ground cable between mowings to see if it holds a charge or is to low to start the mower. If it holds the charge look for a voltage leak, maybe a mouse chewed a wire. If it is still down then it looks like new battery time.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
