JD 130 front wheel hub size
   / JD 130 front wheel hub size #1
dlabrie
Campton, NH
Kubota B2910
I had posted this under the 'tires' forum but thought I might get a reply here...
I have an old JD 130 lawn tractor, circa 1986. The front tire had a blowout and needs to be replaced. I would like to just buy a tire and wheel combo but I can't seem to find the correct size wheel.
The tire is a 13x5.00-6. The wheel has a 3/4" shaft, and the hub length is 2 5/8". Any of the wheels I find online say 3" hub.
Is my JD wheel an odd size or am I missing something?
Thanks.
   / JD 130 front wheel hub size #2
Google AM102452
   / JD 130 front wheel hub size #4
dlabrie - here you go.
13x5.00-6 Orange Wheel w/Bushing
ITEM NUMBER: 1-4143
PRICE: $16.95
SPECIFICATIONS
Size 13X5.00-6
O.D. 13"
Tread Turf
Tread width 4"
Bore 3/4" diam.
Bore Thru-Length 3"
Pressure 30 PSI
Hub Offset 3/4"
Bushing Steel
Tube Type
Ply Rating 2 Ply
Shpg. 8 lbs.
Here is what I would do. Tap out the bushing on the side that has the longer shaft length. Cut off the excess length of the bore, tap the bushing back in. Presto, fixed.
Richard
Thanks, That is an elegant solution! I might have a line on an older JD someone wants to take to the dump. I can grab the wheels off of it if it works out. If not, I might try your solution.
10 ft Shipping Container (A55973)
10 ft Shipping...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2019 Caterpillar 299D3XE High Flow Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
Case skid steer wheels and tires (A56435)
Case skid steer...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
