JD 1140 Alternator Alignment
/ JD 1140 Alternator Alignment #1
shaughnessy
John Deere 1140
Hi Everyone,
When I replaced a failed alternator on my JD1140 I noticed that the pulley doesn't align with the pulleys of the fan and crankshaft. I would say it is about 3/8th of an inch out. The lack of alignment can't be too serious as the tractor has been running that way for years and years, but I'm curious to know whether the mounting bracket can be adjusted fore and aft. I should have looked when I had the alternator off!
Best wishes
Denis
/ JD 1140 Alternator Alignment #2
If possible..... move the alt pulley...dose the belt fit in the new alt pulley ? Mybe you will have to widen the pulley ?
/ JD 1140 Alternator Alignment #3
I don't know about the bracket, but the tabs on the alt could possibly be ground down behind with a grinder for a better fit, adding a washer in the front, this should bring it "back" a bit.
/ JD 1140 Alternator Alignment #4
are you saying the old one did not match or the new one did not match also what year and motor does your tractor have alternator are for exact fit does not need any adjustments in or out unless brackets are wrong also do you a number of the alternator you purchased
Continental Cargo 24' Enclosed Trailer (A66285)
Continental Cargo...
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
Firestone 14.9 x 24 Tire, Unused (A66408)
Firestone 14.9 x...
2018 Kubota SSV 75 Skidsteer (A66285)
2018 Kubota SSV 75...
2013 Ford Explorer 4x4 SUV (A64557)
2013 Ford Explorer...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
