JD 1140 Alternator Alignment
   / JD 1140 Alternator Alignment #1
shaughnessy
John Deere 1140
Hi Everyone,
When I replaced a failed alternator on my JD1140 I noticed that the pulley doesn't align with the pulleys of the fan and crankshaft. I would say it is about 3/8th of an inch out. The lack of alignment can't be too serious as the tractor has been running that way for years and years, but I'm curious to know whether the mounting bracket can be adjusted fore and aft. I should have looked when I had the alternator off!
Best wishes
Denis
   / JD 1140 Alternator Alignment #2
If possible..... move the alt pulley...dose the belt fit in the new alt pulley ? Mybe you will have to widen the pulley ?
   / JD 1140 Alternator Alignment #3
I don't know about the bracket, but the tabs on the alt could possibly be ground down behind with a grinder for a better fit, adding a washer in the front, this should bring it "back" a bit.
   / JD 1140 Alternator Alignment #4
are you saying the old one did not match or the new one did not match also what year and motor does your tractor have alternator are for exact fit does not need any adjustments in or out unless brackets are wrong also do you a number of the alternator you purchased
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
Toro Mower (A50324)
Toro Mower (A50324)
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
2016 FREIGHTLINER CASCADIA DAY CAB (A52141)
2016 FREIGHTLINER...
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
