JD 110 TLB
/ JD 110 TLB #1
bcinphx
JD 110 TLB
Ok, had to re-register for some reason....
Read tons of posts and bought the speed sensor in an effort to stop the surging when driving...didn't work.
I have also cleaned and electrically cleaned the hydrostatic potientometers. Forward and reverse still surge...everything else works as it should.
Another idea please.
Bill
/ JD 110 TLB #2
Sorry Bill… was hoping you would be lucky like I was with the sensor…
The wire connection good and not damaged?
/ JD 110 TLB #3
Are you getting correct voltage out of the potientometers? There is a range from no pedal to full pedal the voltages should be.
/ JD 110 TLB
Waitung on the connectors to make the test equipment. Stupid thing is it drove good for 10 minutes yesterday. And then back to surging.
Bill
/ JD 110 TLB
Built the test connector and pots are at 5 volts. Tractor still surges in drive. Am befuddled.
Bill
/ JD 110 TLB #6
Maybe flywheel engine speed sensor (if you have it) there is a serial number break where it is no longer used.
Or throttle position sensor. It could be at the throttle linkage, or injection pump, depending on your serial number.
/ JD 110 TLB
My '04 does have the flywheel sensor. Umplugged it and tractor starts off a little sluggish but runs/moves in forward and reverse just fine now. Pulled, cleaned a little corrosion off sensor and reinstalled. Running fine at the moment. I will watch it to see if it keeps.
Thanks guys,
Bill
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
Front Tank Bracket (A64127)
Front Tank Bracket...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
TYE 118-610 5 Shank Ripper (A63688)
TYE 118-610 5...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
