jd 110 tlb
   / jd 110 tlb #1
Wrenchin
Bronze Member
RI
John Deere, Ariens, + more
I have ajd110 was blowing hydro component fuse ,replaced HST CONTROLER solved fuse problem ? but indicator light to calibrate all potenteiometers will not show on dash ? I have 95% of harness hanging out of machine found it has 29 different grounds all splice to different colors and wier #s .I checked all volts to all potenteometers .,all ok jumped F-N-R solenoids wheels move tried new dash and another HST CONTROLER same thing /key switch to ;also checked all relays and safety switches .SHOULD I REPLACE THE HARNESS?????? this thing is driving me nuts .the dam thing only has 400 hours ,help of any kind would be awsome:confused2::mad
   / jd 110 tlb #2
I wonder if the new HST controller needs to be calibrated?
Did some add all these grounds? Why would it need 29 grounds?
I'll bet a new harness is big $$$$$. I think I would spend my $$$ on a technical manual that has wiring diagrams and repair the harness.
It (tech manual) should also tell how to calibrate everything.
From what I read there is a fuse that has to be installed for calibration. BUT do NOT just install the fuse, it resets all calibrations to ZERO, NOT to default settings. Then you MUST recalibrate. Did you possibly put a fuse into the calibration slot?
   / jd 110 tlb
hay thanks for reply all the grounds are factory splices I have all test equipment and manuals ,when the fuse is put into calibration slot the service light on dash should come on and start calibration codes .it never comes on ,I have checked most components for shorts but you need pencil fingers to get to some of this crap .I have the jd full calibration kits for 95% of jd tractors all I can find is a bad ground that shorted to a hot becuz HST controller was fried upon cutting it open its almost like some one did some welding on machine and sent a massive jolt threw system but theirs no melted wires .do you think I should remove all HST SOLEINODS to all functions and test them? I work for JD as a tech but never seen this happen.
   / jd 110 tlb
machine starts bucket and backhoe work just wont move ,but unless that calibration light comes on to start code readings nothing can be calibrated I even tried forced calibration using PC NOTHING if any one out there has had this problem let me know. I even filed a case with JD and got less info than I know thay told me that was not a commin problem no ****.
   / jd 110 tlb #5
There is nothing I can do to help, but I wish you the best. Is there anyway to go 'higher up' with help from JD?
   / jd 110 tlb
iam going to try and have them share the bill if I can find a fault in harness ? thanks you guys are great love this fourm, I will be sure to reply all I find once this thing is up and going thanks to evry one .
   / jd 110 tlb #7
I'm not very familiar with Deere in general... I do own a 110 TLB.
Last year I had a problem with the flywheel sensor which made the forward and reverse pedals unresponsive... I was able to limp back to the shed with the creep function.
My heart sank thinking of all the things it could be and it was Christmas and my Birthday all in one when it turned out to be a $65 sensor held on with one bolt.
Just putting this out there...
Here's a link with picture and part number
http://www.tractorbynet.com/forums/...886-4610-surging-issue-fixed.html#post2764832
   / jd 110 tlb #8
You don't mention testing the light itself. Could the bulb be burned out? The light should come on for about 4 seconds each time the key is turned on.
   / jd 110 tlb
yes I did check that to I jumped power to all dash operations all worked just talked with JD rep today going to send me anew harness for half the price because of the low hours it has they told me this is a first one that this has happened ,with no melted wires ,they also told me to replace all spool valve soleinods that have to do with hst they make it sound easy ,like I said before you need pencil fingers , but I have gone this far so im going to remove cab.thanks for reply :confused2:
   / jd 110 tlb #10
Good luck with finding the problem, seems like a lot of parts being changed and doubt they all needed changing.
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2013 Nissan Rogue SUV (A50860)
2013 Nissan Rogue...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
2005 Cadillac STS Sedan (A48082)
2005 Cadillac STS...
LOT LOCATIONS (A51219)
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
