JD 110 TLB rear scv's installation?
   / JD 110 TLB rear scv's installation? #1
mechatgsk
Wilson, NC
Kubota M7060
I have recently come across a new JD 110 TLB that I'm thinking of trading my 4520 compact tractor for. The 110 has the 3rd scv for loader with 4 in 1 bucket, 7 spool backhoe aux hydraulics, quick attach rear bucket, R4 tires. It did not come with the optional triple rear scv's. My question is If I want to add rear scv's can I add a 3 spool valve and plumb it into the existing power beyond quick disconnects? Note: I will have backhoe off of tractor when needing rear scv's.
Regards,
Mechatgsk :)
   / JD 110 TLB rear scv's installation? #2
Since the 110 is an orphan now, the ability of "field installed factory options" will decrease fairly fast. If you are comfortable in doing it yourself it shouldn't be too hard as the 110 had good hyd flow.
Having a 4520 and using the companies 110 tlb frequently. The 110 backhoe will outdig the 4520 with 448 BH. But ground engaging the 4520 will turn circles faster than the 110. Much faster.
   / JD 110 TLB rear scv's installation? #3
I posted in your "buying and pricing thread" about this.
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2015 Ford E-350 Passenger Bus (A50323)
2015 Ford E-350...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
