JD 110 TLB Optional Diverter value and dash light backwards
   / JD 110 TLB Optional Diverter value and dash light backwards #1
JD110TLBFan
Sedro Woolley, WA
2003 JD 110 TLB; 2006 JD 110 TL; JD 6115D; Kutota L245DT
I recently acquired a 2006 JD 110 TLB equipped with the optional diverter value that diverts from front loader and front aux hydraulics to the rear 3 sets of remotes. However, the indicator lights on the dash are reversed, showing the front aux is active when the rear is actually active and showing the rear aux is active when the front is actually active. Also when I turn the tractor on and do not have the Third Function switch activated, it defaults to being switched to the rear making the front loader inoperable by default. I would expect the tractor to default when initially turned on to having a functional front loader. Does anyone know how to correct this so that the dash lights are correct and so that the default when the diverter value hasn't been actuated to be the front hydraulics?
Thanks in advance!
Rhino DB150 (A57148)
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2018 Bell B30E 30 Ton Articulated Dump Truck (A55973)
2018 Bell B30E 30...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
Toro (A56857)
Toro (A56857)
