JD 110 tlb harley rake with TNT??
   / JD 110 tlb harley rake with TNT?? #1
ocsurf16
Beesleys Point, NJ
John Deere 870
I have harley rake with the hydraulic power angle option. It's simply hooked to rear Hydraulics with power toggle switch to operate a valve on top of harley rake. I would like to add a top n tilt kit to the mix, how would i start with this. Can I simply "t" off the existing lines on the rake to get the TNT to work ? I've been searching and have not been able to find someone that has even put a TNT with Harley
   / JD 110 tlb harley rake with TNT?? #2
Can't tee off anything.
Is the Harley rotor driver by hyd or 3pt?
You say you control the angle using a switch, so it must be solenoid operated.
It appears that your tractor is an open center hyd system.
Hydraulics:
Type: open center
Capacity: 15 gal [56.8 L]
Pressure: 3000 psi [206.8 bar]
Total flow: 23.6 gpm [89.3 lpm]
12.2 gpm [46.2 lpm] (loader)
16.3 gpm [61.7 lpm] (backhoe)
Don't know exactly what you have now.
If you have fluid going to the back and it appears you do, then you would install a two or three spool remote valve in the hyd flow path, and make provision for the Harley rake to get fluid from the series flow by feeding the PB from the new valve to the harley valve, and from the Harley rake to the 3pt.
Something along those lines.
All valves should be in series, and all tank lines should go to tank.
If you remove the Harley rake, then jumper the hoses so as to have a series flow path.
Your hyd path might be something like this.
Pump to loader valve, then to the remote, then harley rake, then 3pt, then tank.
Can you show pic of Harley valve.
I will get pictures tom, it runs off 3point not the hydros ...I put an email into a kit I found on here
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A52472)
2008 STEPHENS...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
378583 (A51573)
378583 (A51573)
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
