JD 110 TLB Front auxilliary hydraulics
   / JD 110 TLB Front auxilliary hydraulics #1
drware
Cleveland Tn
John Deere 110 TLB without backhoe, Case 580CK ,massey furgson 175 JD 1020
I'm having a problem with my front auxiliary hydraulics again. Hadn't use it in a month hooked up my hydraulic post hole digger and it would not do anything so I tried my hydraulic chain saw wouldn't do anything either. when I pushed the rocker switch the dash would light up but nothing happens getting 12 volts to both switch and down to both solenoids. don't know where to go now. anybody have any ideas?
Thanks Donnie
   / JD 110 TLB Front auxilliary hydraulics #2
My guess is the valve the solenoid moves is stuck
I was wondering if it might be stuck I replaced a solenoid last year
Have any ideals on how to unstick it without taking it apart
Thanks Donnie
Does anyone know if it would be easier to pull the loader valve assembly to see it the auxiliary valve spool is stuck or try working on it under the tractor?
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
2004 VERMEER BC1000 BRUSH CHIPPER (A50854)
2004 VERMEER...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2005 Kawasaki KAF620E Mule 3010 4x4 Utility Cart (A49461)
2005 Kawasaki...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
