JD 110 TLB and Harley Rake
   / JD 110 TLB and Harley Rake #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
Has anyone with a 110 TLB ran a Harley Rake with the loader? I am probably going to purchase a Harley Rake 72in to use on the skid steer and it would be nice to run it off the 110 if need be.
   / JD 110 TLB and Harley Rake #2
How much flow does the rake require?
The front outlets on the 110tlb are good for 12 gpm, while the rear auxillary hoe outlet is good for 16 gpm. The pressure in both cases is set for 3000 psi.
I would consider using the power beyond circuit with a remote valve on a rear mounted rake as this would give you the maximum use of the hydraulic capabilities. My two cents.
Using the pto you have 31 hp available and really is your best bet.
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2012 Ram 4500 Chassis Vesralift 29ft Bucket Truck (A50323)
2012 Ram 4500...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
