JD 110 TLB 3 point Top N Tilt
   / JD 110 TLB 3 point Top N Tilt #14
The problem with all of the JD top & tilt sets that I have ever seen is that the tilt cylinders are built to have the implement level when fully retracted. On one hand that sounds sort of nice, always know where things are at when fully retracted, problem is that it sure is nice to be able to tilt to both sides and equally at that. Maybe I'm wrong about this, just saying what I personally have seen and heard complaints about the OEM sets.
So be careful about what you get. ;)
Brian, if you were to provide the top cyl. for the 110tlb what would you make the retracted length, pin to pin.
   / JD 110 TLB 3 point Top N Tilt #15
I provide a 2 1/2" dia cylinder with a 1 1/2" dia rod with a working length of 18 1/4"- 25 1/4" for the 110 TLB.
   / JD 110 TLB 3 point Top N Tilt #16
Brian thanks, i just bought a new LVB25904 the factory top and tilt deleivered ($1400.00) and wanted to compare the difference because of the comment above.
the retracted length here is 19 1/4 compared to your 18 1/4"
   / JD 110 TLB 3 point Top N Tilt #17
and the retracted length of your tilt cyl?
factory is 18 1/4" center pin to center slot.
   / JD 110 TLB 3 point Top N Tilt #18
The JD factory 110 top & tilt set that I have measured had the top link right at 20" fully retracted. So they have made some changes and or have a different supplier.
I build my side links to be level with the rod half way extended. This gets you an equal amount of tilt angle to each side. The mid point measurement that I have for the 110TLB is 21". That is with the pin locked down at the bottom of the slot.
AS far as the top link, what is your pin-pin distance with your box blade level front to back? Have both the front and rear cutting edges 1" off of a flat surface when getting this measurement.
   / JD 110 TLB 3 point Top N Tilt #19
Brian, i don't have the 110tlb home yet to help you with those measurements. (a uship story for another day)
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
UNUSED FUTURE QUICK ATTACH PLATE (A54757)
UNUSED FUTURE...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A55788)
2017 Ford F-350...
