JD 1070 clutch noise
   / JD 1070 clutch noise #1
ndgregor
Wind Gap, PA
John Deere 1070
I have noticed the following going on with my JD 1070. MFWD and roughly 1500 hours.
When the weather is cold out (below 40 F), when the tractor is started and initially put into gear upon releasing the clutch there is a slight grinding noise that comes from the transmission. This is not a grinding sound as if you were jamming it into a gear, more of a soft grind/rubbing sound. It starts as the clutch begins to engage and stops once the clutch is completely engaged and the tractor is moving. You can feel a slight vibration through the clutch pedal. I have also noticed that once a few shifts are made, and the tractor is operated for a bit the noise goes away entirely. While it is cold, the noise is more pronounced the higher the gear that you start in. There is no noise when engaging the clutch in neutral.
No performance issue has been detected, and I was able to pull a 2x12 plow two weeks ago through tough ground with no problem. Any thoughts/ideas?
   / JD 1070 clutch noise #2
For the age of the tractor you might have the clutch shaft getting dry or parts in the transmission. To only have when cold, metal is a different size and it might not be a real problem. the transmission is up to proper level?
   / JD 1070 clutch noise #3
Maybe the throw out bearing is dry? Or as stated, slight galling of a dry input shaft.
Jim
   / JD 1070 clutch noise #4
Cooler weather could make the TO bearing stiff until the grease is warmed up and makes it easier to spin. Or it could be on its way out. Warmer weather will tell. For time being id engage at a low RPM
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
