Loader JD 1070 assistance neede
   / JD 1070 assistance neede #1
BuzzyG
Hello, boys! I hope all is well with you.
This seems like a really stupid question, but here it is.
I have just acquired a John Deere 1070 that works well in every capacity. But I cannot find two things:
1. The 4WD switch.
2. A place to add hydraulic fluid.
Can you help me with that?
Thanks!
   / JD 1070 assistance neede #2
Engage 4wd by pulling up on a small fwd facing lever on the left side of the seat platform. It should rise up about 1" when fully engaged. Best to do this when the tractor is moving and with the clutch in. Same for disconnect. Shove the lever down ward.
Add hydraulic fluid at the back by removing the yellow plastic cap twist off cap.
Check fuel filters, one at the base of the tank and the one everybody forgets about at the engine on the right side at the injector pump.
Thank you so much.
I should be on the way to usefulness now.
2018 Ford F350 (A55973)
2018 Ford F350...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
CFG Industrial H15R (A56469)
CFG Industrial...
UNUSED FUTURE FR70 70" HYD FLAT RIPPER (A57193)
UNUSED FUTURE FR70...
