JD 1050
   / JD 1050 #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
My 1050 wants to pop out of reverse unless I keep my hand on the shifter. I took the cover off and found that that reverse shift rail does not want to slide all the way into position like the other rails. The fork appears not to be bent, the detent ball bearings are new as well as the springs. Any insight?
   / JD 1050 #2
On my Tacoma pickup, a little teflon bushing just below the shifter ball area broke and caused it to not stay in 5th gear. Could your 1050 have some sort of gizmo like this?
Ralph
   / JD 1050
No, there is nothing like that in the 1050.
   / JD 1050
I found problem that kicks my tranny out of reverse. I long bolt used to hold the tractor clutch housing to the tranny housing was preventing the reverse idler gear to move into position. A shorter bolt solved that problem.
2008 International 4400 Terex Hi-Ranger HRX-55 55ft Material Handling Insulated Bucket Truck (A48081)
2008 International...
2016 HINO 268 26FT BOX TRUCK (A45679)
2016 HINO 268 26FT...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A48081)
Unused 2025 40ft...
Clark CGP20 Forklift (A48837)
Clark CGP20...
New/Unused 20ft x 20ft Container Shelter (A48837)
New/Unused 20ft x...
1999 Pierce Quantum Fire Truck (A48081)
1999 Pierce...
