Oil & Fuel JD 1050 oil pressure question
/ JD 1050 oil pressure question #1
motorhead2
I have a JD 1050 with over 9400 hrs on it. I was told when I bought it a rebuild was done at about 7K hrs. It seems to run fine but something concerns me and I'm wondering if it is normal for this tractor. The question is when I start up cold the oil pressure is 50 psi. After warming up it drops off to 20 psi at PTO speed. Idling down to 1500 or so RPM can drop it to 15 psi. Is unusual bearing wear common to this tractor or maybe pump wear? Otherwise this is a great tractor.
/ JD 1050 oil pressure question #2
:welcome:
Are you getting oil pressure from a guage? Parts shows an oil pressure switch, to me indicating an idiot light.
Shows it on the front left side of engine. Maybe it has been changed out for a pressure guage to give you the different readings.
Do you hear any difference in the 'knocking' sound from the engine when the pressure changes?
Depending on what all was done at "rebuild" time, but maybe oil pump needs changing (for first time or again). Those are some good hours for the 1050 Yanmar engine.
I made up a new dash panel for this tractor because I didn't want to rely on the idiot lights. In addition to the vast original gauge set I have oil pressure, temp, voltmeter and a timer for the thermostart made from an old rear window defroster relay for a mid 70s GM car so I don't have to hold the key. I replaced the puny alternator with one for an '86 or so Subaru XT - bolts on nicely and can eliminate the external reg. And, yes, this tractor was rewired. Getting back to the original post, no significant knocking sound though I wonder if the mains may be worn since the sound is more of a thud irregardless of pressure change not really a rod knock - that would be sharper. It is more pronounced around 1500-1600 RPM than any other time. I have had an unexplained coolant loss in the cold months amounting to maybe a half pint over the course of that time. No wet head gasket edge or leaking water pump or hoses. No coolant appears in the drained oil yet there is a small amount of "shaving cream" coming out the breather. When I bought the tractor it had no thermostat in it keeping it cooler than it should be. Barely got above 100F in the winter even with radiator half blocked. Heck, I could hold the muffler bare handed after several minutes of operation! Now has a 170F stat. Wouldn't be surprised if everything ties together. Probably wouldn't hurt either to go through this motor and redo it. *OUCH* the thought just hurts the wallet.
