JD 1026r wont start
   / JD 1026r wont start #1
rtunney
crossriver, ny
JD 1026r
have a new JD 1026r diesel, six mos old, and past 2 times using it when i tried to start it it wouldnt turn over, message on dash says put in neutral which i did and still had trouble. It started after a bit. Today it did the same after running for about 5 hrs cutting grass with the rear brush cutter. It wouldnt start no matter what, i left it for a bit and came back and it tries to start for a second then doesnt turn over and same message. The dealer is closed and i was wondering if anyone has any ideas. I guess its under warranty so the dealer will have to fix it?
   / JD 1026r wont start #2
Does the light stay on after you have the machine in neutral? It sounds like the switch that tells it when you are in neutral could be out of adjustment or malfunctioning.
I think thats exactly it, there must be some sort of kill switch that tells the starter im in neutral. I never had this with my JD 425, so dont know what i can do other than wait for the dealer. Any ideas are appreciated
   / JD 1026r wont start #4
It might not be that difficult to fix yourself if it is just out of adjustment. It probably has a jamb nut on either side of a bracket, loosen one and tighten the other to move the switch closer to the lever to make contact.
If you don't want to try and fix it yourself just wiggle the lever while in neutral and see if you can get it to start until you can get to the dealer.
2011 Terex Fuchs MHL340 Wheeled Material Handler (A49346)
2011 Terex Fuchs...
2019 Nissan Versa Sedan (A46684)
2019 Nissan Versa...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2016 Chevrolet...
Earthway Seeder (A48837)
Earthway Seeder...
Stainless Steel Tailgate Spreader (A49251)
Stainless Steel...
2016 Ford Transit 250 Cargo Van (A46683)
2016 Ford Transit...
