JD 1025 transmission question/problem
/ JD 1025 transmission question/problem #1
JAMES KELLEY
MEADVILLE, PA
JD1025
I have a JD 1025 with approximately 25 hours on it. I noticed when I was installing mower deck yesterday, that the tractor move forward with transmission engaged in either low or high range-- before forward pedal was engaged. Also have difficulty in shifting/ transmission out of high or low speed ranges with the engine running. Have called the dealer already-just wondering if anyone else has experienced similar problems.
/ JD 1025 transmission question/problem #2
As far as shifting goes try moving forward and backward very slowly while shifting as that should help , I have to do that when I go from 4wd to 2wd or vice versa . As far as going forward when not supposed to that should just be an adjusment the dealer can help you with .
/ JD 1025 transmission question/problem #3
There is a pedal position adjustment under the cover below the seat (red circle). I don't have the instructions for the adjustment but they are on the net if you look. The tractor does not have to come apart like this to make the adjustment , I was installing the independent lift.
/ JD 1025 transmission question/problem #4
The dealer should make the adjustment on warranty with those few hours.
Mine won't shift on the fly from L to H like the 4010 used to. Have to be totally stopped.
Shifting from 2wd to 4wd and back is so much easier on the 1025 than it ever was on 4010.
Ralph
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
2022 EZ-GO ELITE...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
