JD 1025 ROCKSHAFT CONTROL LEVER
   / JD 1025 ROCKSHAFT CONTROL LEVER #1
JAMES KELLEY
MEADVILLE, PA
JD1025
Has anyone had any experience with the rockshaft control lever staying in the raised position by itself. It raises and lowers mower deck okay but I have to hold it in the raised position. Tractor has 100 hours on it and is under warranty but getting fast service this time of year probably will not happen. Any suggestions/solutions would be greatly appreciated.
   / JD 1025 ROCKSHAFT CONTROL LEVER #2
If I hear you right, then there are friction washers that hold the lever at one location, and they need to be tighter.
Look at the pivot point just below the two bolts that hold the lever arm on, and there is a lock nut that you can tighten.
Should solve the problem.
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
2014 XL SPECIALIZED TRAILER XL 110 HDG RGN (A52472)
2014 XL...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
