JD 1025 ROCKSHAFT CONTROL LEVER
   / JD 1025 ROCKSHAFT CONTROL LEVER #1
JAMES KELLEY
MEADVILLE, PA
JD1025
Has anyone had any experience with the rockshaft control lever staying in the raised position by itself. It raises and lowers mower deck okay but I have to hold it in the raised position. Tractor has 100 hours on it and is under warranty but getting fast service this time of year probably will not happen. Any suggestions/solutions would be greatly appreciated.
   / JD 1025 ROCKSHAFT CONTROL LEVER #2
If I hear you right, then there are friction washers that hold the lever at one location, and they need to be tighter.
Look at the pivot point just below the two bolts that hold the lever arm on, and there is a lock nut that you can tighten.
Should solve the problem.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
John Deere 47" Snowblower (A50774)
John Deere 47"...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
Toro Workman Utility Cart (A51694)
Toro Workman...
New Holland 489 Haybine (A50774)
New Holland 489...
