JD 1025 Mower Deck Stand Reply
   / JD 1025 Mower Deck Stand Reply #1
JAMES KELLEY
MEADVILLE, PA
JD1025
Thanks for all the replies to my inquiry on the deck stand for the JD 1025 60" deck. I have s similar set up to Larry's Axles currently which I use for moving and storage. The difficulty is the process involved in getting the mower deck in a vertical position and then moving it into a place for storage. I currently use an engine crane to lift (after blocking it up to get under the deck) to install the axles. The deck dolly look like a possible solution-just curious how easy it is to lift the deck-the man in the video is pretty well built. I have read the ratings and probably would go with the longer handles. When you are my age-67 (and after back surgery) you ask more questions and have to decide between what you can do and what you should do! Thanks again for all your replies.
   / JD 1025 Mower Deck Stand Reply #2
I am 67, no back problems, and I would never dream of trying to lift my 62D deck. Do you have a front end loader? I use that to lift it vertically. I just use axles on mine, but I understand the desire to have it easier to move. When I need to move things (snowblower, box blade) I just buy two Harbor Freight moving dollies (1000 lb capacity each) when they are on sale for $8 and build an equipment dolly. I think you could build a cradle on each dolly to accept your axles.
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2015 Toro Z Master Professional 64in Zero Turn Mower (A50322)
2015 Toro Z Master...
2015 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
