Buying Advice JD 1023E vs 2320
   / JD 1023E vs 2320 #11
If this thread goes long enough you'll be in a 9630.
   / JD 1023E vs 2320 #12
he should buy a komatsu 575 and just level the property at this point
   / JD 1023E vs 2320 #13
I agree with above, if you gotta go deere at least a 2520. I think I drove almost every tractor made in the last few weeks and the 2520/3032e was at the top of the list. They ain't cheap though!
   / JD 1023E vs 2320 #14
Selecting the right sized tractor can be difficult for all of us. Alot depends on what condition your place is in and what you plan to do about it. For instance if it is relatively smooth and flat and has small brush to remove you can get by with an L&G or subcompact. If you need to move boulders, install drainage ditches or make large changes in existing grades you will need a much larger machine(s). If you have enough large projects and sizable property to maintain choosing the larger equipment is more feasable. You may still need a small machine for the lawn and garden areas though.
   / JD 1023E vs 2320 #15
I usually seem to wind up supporting the little tractor choice, but I think it was said best above: There is a huge difference with initial contouring and taming vs maintenance. I think you will find the 1xxx small for making large grade changes in the property. I love my 1026R TLB and it's really perfect for upkeep on something like you are talking about (even including small additions), but the initial work will be a whole different level. I don't have the experience to best help you find the size you need, but I can tell you the 1xxx isn't it. :)
   / JD 1023E vs 2320 #16
IF you are going to even CONSIDER the 4XXX series I wouldn't settle for less than a 4120. It is the smallest "Deere" product with an actual "Deere" motor! Below that you're stuck with Yanmars. Which are great and cool with the smaller tractors. I'd rather have a Yanmar than a Kawasaki.
   / JD 1023E vs 2320 #17
I know the new financing makes looking at used less attractive, but I would suggest looking at your dealers used stock, and seeing if a larger tractor can be had for a similar cash outlay.
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
International 475 14 ft Disc Harrow (A52128)
International 475...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
