JD 1023 / 1026 capable of using brush hog?
   / JD 1023 / 1026 capable of using brush hog?
Seriously looking at the Mahindra max 28 XL with gear/shuttle transmission.
   / JD 1023 / 1026 capable of using brush hog? #12
Do you have any other uses for your tractor, besides mowing the 15 acre field a couple times a year, and finish mowing the 4 acres? Are you planning on doing anything with the remaining 56 acres of land you have?
Are you retired with a lot of time on your hands?
Are you the type of person who typically tries to use the smallest tool available, that is just enough to get the job done? I'm asking because some people have a lot of land, with a lot of work to do, that is technically possible with a very small tractor, it just takes a really long time. But, if your that type of person who doesn't mind, then a subcompact may be just fine. :confused3:
   / JD 1023 / 1026 capable of using brush hog? #13
for mowing that much i would look for a big used 2wd utility tractor with 45-50pto hp so you can run a big multi rotor cutter/big finish mower for the yard. then get a small lawn mower or zero turn for the clean up work that you would miss with the big tractor.
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2023 HELI CPYD25C FORKLIFT (A58216)
2023 HELI CPYD25C...
20" X 24" ROLLING METAL CART (A58374)
20" X 24" ROLLING...
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Enerpac RCS302 30-Ton Low Height Hydraulic Cylinder, 5" Tall (A59076)
Enerpac RCS302...
