JD 1010 bulldozer
   / JD 1010 bulldozer #1
philbuilt
Maine
1260 Massey/retired. Mahindra 2555 cab TLB
John Deere 1010 bulldozer is this a good dozer for $3500.
I has been used little and well maintained. What should I look for?
Thanks
Phil
   / JD 1010 bulldozer #2
Hello Phil, For that kind of money if it runs, pushes, and steers get it. I wouldn't expect too much though because it does seem cheap. The problem with cheap is when you have to fix it up to your liking the costs goes HIGH. :( But if it runs till your jobs are done you did REAL good. :) My cheapest dozer I sell with 6 way blades and good u/c is $7500 but even then the units need tlc. If you want and need a real nice one then the price woudl be in the mid teens. Good luck
Darin
Thanks
Phil
   / JD 1010 bulldozer #3
I never heard of it, so I did a quick google search and found this site.
The John Deere 1010 Industrial
They think this might be the worse tractor Deere ever made. Not sure if that's true or not, but I sure wouldn't want one for anything if I needed it to do some work. If you are buying it as a collector, then it's just a price thing.
Eddie
   / JD 1010 bulldozer #4
Thanks
Phil
I purchased a 1010c about three years ago with a gearmatic winch. I used it to put in a rock wall, build up and fix my road, skid out trees, move stumps, multiple landscape projects and push back snowbanks, etc....I had to replace a front idler and few "wear" items such as a starter and generator but for the most part it has been very reliable for a forty year old piece of equipment...it will push and pull pretty much what I put in front or back of it. I paid $5500.00 for it three years ago and it owes me nothing!
Check to see how the tractor steers and how it goes into gear especially reverse. Take a close look at the front idlers and make sure that there is plenty of meat on the rails to keep the tracks in place. Be sure the track tensioner is operational and that there is no broken springs also look at the overall condition of the rollers /track.
I've had good luck with my 1010C, its a real work horse. If yours is in a well maintained condition as you stated, you should have no problem getting $3500.00 worth of work out of her.
2018 Chevrolet Tahoe (A51694)
2018 Chevrolet...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2018 Caterpillar 308E2 CR Mini Excavator (A52377)
2018 Caterpillar...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
SDLANCH MINI WALK BEHIND SDLL30 LOADER (A53843)
SDLANCH MINI WALK...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
