JCB vs Boulder...pictures attached
   / JCB vs Boulder...pictures attached #1
GaryInWA
Western Washington
JCB 1400B backhoe, Kubota B21
I am currently clearing a site for my garage and encountered a rather large boulder. I have moved some pretty good sized rocks with my JCB 1400B but this was the biggest yet. I had to remove it as it was in the way of the concrete slab, I was able to build a ramp and pull it out with the backhoe, boy am I glad I own a fullsize backhoe :)
I attached some pictures of me attacking the boulder and getting it out of the way.
PS: The rear tire of my backhoe is 4 feet tall and my backhoe bucket is 24" wide to add some perspective
   / JCB vs Boulder...pictures attached #2
Looks like th JBC won!!!!!:D
   / JCB vs Boulder...pictures attached #3
Heck man, if you had the thumb on you could have just picked it up!
   / JCB vs Boulder...pictures attached #4
That’s a rock alright! Not sure my little Kubota would have made that happen.
MarkV
   / JCB vs Boulder...pictures attached #5
Horsepower sure is fun huh?
I've got a 1550-B
   / JCB vs Boulder...pictures attached #6
Yeah, a thumb and 5 others hoes. I bet that rock weighs 20,000 lbs. Once you get under it they don't move too bad but it sure is a lot of work to get under it in the 1st place. Nice job of removing it. later, Nat
   / JCB vs Boulder...pictures attached #7
For sure it's nice to have a full size hoe. I have one also. When I was a kid my father and I used to move rocks , probably not that big but pretty big ,with pinch bars and smaller rocks and it took days when we had nothing else to do. Sort of miss those days.
   / JCB vs Boulder...pictures attached #8
That'd be a good one to put your mailbox on to keep the vandals away!
   / JCB vs Boulder...pictures attached #9
Nat, I read your reply and thought -- Nawwww. Then started thinking. It's about cube 5' on a side. That makes it 125 cu ft of volume. Granite is about 125#/cu ft, so the rough estimate is 15,625#. Hey, that's a BIG rock! And a good estimate by you!
jb
   / JCB vs Boulder...pictures attached #10
Congrats on a getting it out. Now what do you do with it?
I've had stumps in that size range, but never anything as heavy as that boulder. Those stumps are almost as hard to get to the burn pile as getting them out. I don't even want to think what it took to move that thing around.
Thanks for the pics, they are allot of fun.
Eddie
Case 1083 20ft Corn Head (A53473)
Case 1083 20ft...
Bead Blaster Parts Cleaner (A51695)
Bead Blaster Parts...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2017 Ford F750 Buck Truck (A52377)
2017 Ford F750...
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
