Jarp 12 volt Hydraulic pump
   / Jarp 12 volt Hydraulic pump #1
Agent Blue
Platinum Member
A friend gave me a 12 volt pump for the dump trailer I am building. The aluminum case says JARP which is a firm in Wausau, Wi that manufactures hydraulic rams for escavators. The pump connected to the starter has John S. Barnes Corp. written on it and a model number of GC 5052 A CA 1. I can't find anything on the net about this pump as far as capacity or pressure. I guess the only route to take is install it and see if it can do the job.
Thanks JJ,
Thats what I was guessing . I think it will work for my application but the aluminum tank might not hold enough oil for the 5x15 ram. I checked it with water and it held 2 and 1/3 quarts. I will plug it in and try it. May have to weld up a larger tank but the main issue is if the pump works properly.
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
1997 STOUGHTON TRAILER DRYVAN (A53843)
1997 STOUGHTON...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
