Tiller Japanese Tillers
   / Japanese Tillers
It does seem logical that these tillers do work well in our soil, If they didn't there would be a lot of ticked off people who bought them. I still can't help but wonder why a dealer would make a comment like that. /forums/images/graemlins/confused.gif
   / Japanese Tillers #12
I did happen to find this web page;
The tiller pictured has the look I associate with the tillers on grey market tractors, including the sickle shaped blade noted previously in this thread. But that bottom picture certainly isn't a flooded paddy.
The two phrases that seem to relate to this discussion are "greater adaptability to hard soil' and "rotary tiller paddy field vehicle".
The stumbling block in making use of this is understanding what is meant by "hard soil". Is this term being used in the way we would, to indicate soil types that are particularly in contrast to other soil types? Or does in mean solid earth as opposed to muddy conditions? Is this research significantly different than that which might be undertaken to improve a domestic tillers "adaptability to hard soil"?
As usual, I provide no answers /forums/images/graemlins/tongue.gif but enjoy it all anyway /forums/images/graemlins/smile.gif
   / Japanese Tillers #13
My neighbor has to have the newest toys aroaund, we took dads YM3000 and his 5 foot yanmar tiller thats been used so much the sheet metal has holes worn in it and my neighbor took his 950 J and new Howard rotovater after telling my his dealer said they wer inferior. We set out tilling a garden and he couldnt tell the different sections that i tilled from his. Then i told him what i gave for it 200 dollars and he got ill over my inferior tiller worked good as his
   / Japanese Tillers #14
I have a nice yanmar tiller on the back of my yanmar tractor. Works great. The tines are similar size and shape to just about every US made tiller so I am betting the rumor is to keep you from bying the $300 japaneese tiller instead of the $800 us tiller.
   / Japanese Tillers #15
I don't know what type of soil you plan to till, but I can tell you that I have tilled very rocky soil with my Yanmar imported tillers (I currently have 3 tractors and 3 tillers). They all work very well. I even loaned one of the tractors and tillers to a friend who used it to till very hard clay with lots of rocks. Man did that tiller bounce and make noise - I could even see sparks under the tiller while it was working. It never broke or had any other problems except that the shaking was so violent that one of the large (~1 inch diameter) mounting pins came out and got lost in the tillage somewhere.
Personally, I wouldn't use the tiller to do this kind of work and I would never loan it out for the same kind of use again. But the point is that the tiller and tractor stood up to the task without any mechanical problems. The tillers are rather large for the tractor sizes - the 13 (engine) hp tractors have 1 meter (3ft) wide tillers, the 16 (engine) hp tractor has a 1.2 meter (just under 4ft) tiller.
I think you just need to be aware that the Japanese gray market import tillers are not built as heavy as one built for the U.S., and you need to take it slow and easy - especially on the first pass. They are a fantastic value for the money - usually around $100/ft of width for one in good condition.
   / Japanese Tillers #16
I've got a Yanmar tiller behind my Iseki tractor. Have no complaints on the tiller, other than I had to do some work on the PTO shaft to get it to fit. I have heavy clay soil with plenty of rocks and I haven't torn anything up. The best part was the price - $300. I don't use it every day, if I did I'm not sure I wouldn't use it until it fell apart then buy another one. /forums/images/graemlins/smile.gif
Jeff
   / Japanese Tillers #17
Are you guys referring to 3 pt or 2 pt tillers?? A local dealer has 2 Yanmar 1401's with tillers, but they are 2 pt. I have a Yanmar YM180D with Cat. 1 3 pt. Can the tiller be made to fit my standard 3 pt hookup??
Regards,
Brian
   / Japanese Tillers #18
My tiller is a 3 point. When I bought my tiller they had a couple of 2 point tillers. I glanced at them but don't have a clue what it would take to convert them, or if you could. If it were me I'd just find a 3 point tiller. Most of the importers have a few sitting around.
Jeff
   / Japanese Tillers #19
I have a Kubota B6000 (12hp) with 2 pt 3ft wide factory fitted tiller. [Now my second tractor and only used for tilling duties].
As has been mentioned these have curved "knives" which cut into the ground. Tractor has 3 speed pto for tiller work.
On heavy clay un-tilled sod, I have to make several passes with tiller at lowest speed. The nature of the cutting action does not always lift and turn the sod out. It could be 4 or 5 runs, increasing pto speed every other time before I would have a workable soil. It is only the top pto speed which pulverises' to a reasonably fine tilth.
The advantage is that the design requires less hp to operate the tiller and by their shape are not affected by stones and the like as with standard tiller cutters. The tiller will bounce over stones and bury them slightly rather than fighting and bringing them to the surface.
Having used a 7ft "Howard" rotovator behind a Ford 4000 for many years, they are nowhere near as good for producing a fine powdery tilth. However I believe the design and operation makes them more robust and less prone to operational damage. That's why they can be directly bolted to pto housing and do not have shear pins or slip clutches.
Don't be afraid to buy and use one, but beware that they do not operate in the same way and do not produce the same results.
As always, it will depend on the reason you want to till and the finish you require.
   / Japanese Tillers #20
Here's a picture of a Japanese rice paddy. They have super lightweight tractors for going through the mud. They use the more typical CUTs for working the soil when it is much drier. The next picture shows a close up of the tractor.
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2021 Toyota Rav4 AWD SUV (A55853)
2021 Toyota Rav4...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
