Jacobsen Turfcat - reverse problem
   / Jacobsen Turfcat - reverse problem #1
Hex
Europe
Jacobsen, Kubota, New Holland, Toro, Ursus, CAT, ASV, Takeuchi...
I have Jacobsen 523d TurfCat.
Recently there are problems with switching driving directions. Can't drive backwards, need to press the leaver couple of times, and it starts to react and drives back. Sometimes it works sometimes not... Frustrating...
I've changed the hydraulic oil and the filter. It doesn't help much.
Do you think it's the problem with hudraulic oil pump or sth. else?
   / Jacobsen Turfcat - reverse problem #2
I would first double check to make the linkage is consistent in moving the swash plate in reverse direction.
You are 100% right @oldnslo.
The linkage was loose and worn our after so many years of using.
It works now, however in the future I will need to regenerate the connection in the pump.
I'm glad that it's not the problem with the pump itself.
   / Jacobsen Turfcat - reverse problem #4
Hex
Appreciate you letting us know what the problem was and wishing you the best on repairing the linkage.
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A53421)
2017 Kawasaki Mule...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
