Has anyone found a good jack point to lift the rear tires? The loader frame is in the way to get a clean shot at the rear axle and I don't think I want to lift on the loader frame or the 3 pt stabilizer mount.
/ Jacking the rear tires off the ground on a MT357
I do! If I need to lift one side, I simply place a small block of wood under the loader frame and jack it up. If I need both rears jacked at the same time (like when I install snow chains) I use the drawbar, or rather, directly underneath the drawbar. Then place jack stands on the loader frames and ease it down. Both tires off the ground and spin freely. Simple enough.
