J2023 vs J2030
/ J2023 vs J2030 #1
Olympus
Platinum Member
Cape Girardeau, MO
LS R3039
So I've pretty much locked down my choice for LS as my next tractor. Just trying to decide on a model now. I just did a quick test drive on a '14 model J2023, but I just found another dealer who has a new '13 J2030 that he just got in Nov/Dec. He quoted me $12,200 on a 14' model 2023 that he would have to order. He quoted the '13 model 2030 at $12,500 and acted like he'd be willing to work on the price of the 2030 instead of having me order the 2023.
My question is aside from the difference of HP, 23 vs 27, is one model better than the other? I know the '14 models have a bigger hydro pump and they also moved to the dual pedal system instead of the rocker system. My initial thoughts are that the bigger pump and dual pedals would be better in my situation instead of the bigger hp difference. I have a 20hp JD right now and it is plenty of power for what I need. I'm going to do go by this dealer and test the 2030 and see if they will come off the price much more for the 2030 they have in stock.
/ J2023 vs J2030
Also looks like the new 2023 has a loader capacity of 1270 lbs while the 2030 has 1150. So 120 lbs less loader capacity with the 2030. That's a lot more than I would have thought.
/ J2023 vs J2030 #3
The 2014 should be the tier IV engine and may have a lot more environmental stuff on it than the 2013 year. Check out the differences and what kind of extra servicing might be required for the 2014 vs the 2013. Might be a pleasant surprise in that the less HP might be more net HP without all the smog junk.
/ J2023 vs J2030 #5
I'll do some research on that. Thanks.
It's my understanding that tier IV requirements for 2014 only apply to engines that put out less than 19kw of power (less than 25hp)- so the 2023 should not have a bunch of tier IV emission compliance hardware. I think that is why LS discontinued the 2030 - at 27 hp it would have required expensive updates to exhaust system.
/ J2023 vs J2030
I was not aware of that. That's definitely good to know. So you're saying the 2023 or the 2030 would not be a Tier 4 engine?
/ J2023 vs J2030 #7
That's my understanding- but you should verify with dealer or LS directly- The LS web site lists the 2023 engine as "tier IV interim" whatever that means- it doesn't say anything like that about the 2030- i suspect since the 2030 still has the single pedal HST they are all last year production and when they are gone- no more 2030- again check with dealer- I also think the 2023 "interim" engine may be just waiting for gov't approval as it has always been the same displacement as the 2030 and just a bit of fine tuning (I was told Turning up the injectors??) could bring it to 27 hp-- My problem is "a little knowledge is dangerous" let me know what you find out- hope I helped rather than confuse.
/ J2023 vs J2030 #8
Neither the 2023 or the 2030 are Tier 4. The Tier 4 versions will be available this fall as the XJ-25.
/ J2023 vs J2030 #9
Thanks fr the info. diamondr--do you know what's with the "interim tier IV" designation on the LS website for the 2023?
/ J2023 vs J2030
Yeah, what does "interim" mean exactly in terms of actual changes to the engine?
/ J2023 vs J2030
I just took a look at the 2030. The rocker pedal was a deal breaker for me. It was uncomfortable for me.
/ J2023 vs J2030 #12
At first I felt the same way-- I took a chance and now after 7.5 hours of use- I think it's OK... I was use to two pedals but am getting better and better at the rocker--
/ J2023 vs J2030
I don't like the feeling of having one knee bent up higher than the other. The 2023 was $300 cheaper, 120 lbs more loader capacity, and a bigger hydro pump. 4 more hp just isn't worth it to me.
/ J2023 vs J2030 #14
I know what you mean... good luck - and congrats on choosing a great brand.
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
8' DISC HARROW (A60430)
8' DISC HARROW...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
HE WASHING MACHINE & DRYER (A62131)
HE WASHING MACHINE...
