J2020H Turns on, turns off when is released
   / J2020H Turns on, turns off when is released #1
Jherna7
LS J2020H
1. This J2020H Tractor I bought in 2013 is not a power house but does what I need on a sandy soil 30 acres.
2. First the problem began with turning the ignition key on and it wouldn't start.
3. One day out of frustration I turned the key on and off about four times and it started. I was able to use the tractor.
4. The next day when I turned the ignition key to START it started the engine but as soon as I let loose the key the engine shut off.
5. At this point I assumed it was a faulty ignition switch so I ordered and replaced the ignition switch with a new LS J2020H switch. Exact same switch.
6. The new switch didn't solve the problem. Still when I turn the key to START position it will start. If I keep the key in START position the engine continues to run. But as soon as I let go the key the engine shuts off. If I hold the key on START the engine continues to run.
   / J2020H Turns on, turns off when is released #2
Have you checked the wiring? dirty connections
or grounded wire? solenoid OK? can you jump the
solenoid to see if it will crank?
willy
   / J2020H Turns on, turns off when is released #3
Starter relay perhaps.. Have a wiring schematic so you can trace it out and see what/if relays are suppose to engage?
   / J2020H Turns on, turns off when is released #4
On mine, anytime mine wouldn't crank- it was a finicky PTO switch.
   / J2020H Turns on, turns off when is released #5
Did you ever solve your problem. I have the same issue..
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
