J Deere 430 loader on 4300 tractor
   / J Deere 430 loader on 4300 tractor #1
wrede
2001 J. Deere 4300
I need to replace the seals on the bucket curl cylinders, and have ordered parts. The loader was built in 2001 and has a higher serial number (017xxx), as I know they changed the design a few times. I see that the cylinder has a spring ring on the end, but I can't understand how it comes apart. Is there another ring internally that holds it together? Haven't found a repair manual yet that shows it. Any comments on the manual or the job?
Thank you very much. Yes, now I understand the design. Remove the external circlip to push the cylinder "head" in, place orange plastic split ring in groove in the inside diameter of the cylinder, and yank the assembly out. The split orange ring fills the groove on the inside diameter which allows the internal metal ring to compress and go past the groove. Interesting design, clearly not obvious from the outside, or for that matter from the parts explosion diagram. I'm thinking I can leave the cylinder attached to the upper pin connection, using it as my "vise", and then plunge it in and yank it out like a sliding hammer. I have the parts and need to get up my courage to give it a whirl. Again, thanks for getting me the details.
   / J Deere 430 loader on 4300 tractor #4
Your welcome ;)
1264 (A50490)
1264 (A50490)
UNUSED AGT QUICK ATTACH HYD DROP HAMMER (A51244)
UNUSED AGT QUICK...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
LILL 1044C-54 SERIES II FORKLIFT (A50322)
LILL 1044C-54...
