J/D5100 bucket curls slow?
   / J/D5100 bucket curls slow? #1
mikenmichele
J/D 4100
Hi! I have a 2001 5100 tractor and seems like Im having some issues with the bucket curling up slow and making a straining noise. All the other positions are fine and labor free although I do have issues going uphill in high gear and when there is a heavy load in the bucket the power steering doesn't work good and is hard to turn. Any thoughts? Thanks!!
   / J/D5100 bucket curls slow? #2
Check filters, screens, fluid level, and reset all your QD's.
Install a hyd gage in the hyd system and take some readings.
If you read relief pressure before the cyl is fully extended or fully retracted, a QD is probably the cause.
Thanks for the reply!! Whats a qd and how is it reset? LOL Im pretty mechanical but never heard that term?
   / J/D5100 bucket curls slow? #4
Hello, a QD is a abridgement of quick disconnect. Resetting them, means disconnect it, and connect it again.
I hope I could help you.
Wilco
OH...LOL Ya that was easy!!
LOL yea that was easy. I did uncouple all 4 of them and reattached but no better. Am I to do something different than just disconnect and reconnect?
   / J/D5100 bucket curls slow? #8
Don't forget to NOT leave the 3PH lever in the "UP" position......that'll make things not work also
   / J/D5100 bucket curls slow? #9
Are you saying that the lift cyl's work fine.
yes everything else works good other than power steering when bucket is fully loaded or Im carrying something heavy, bucket curls slow is only issue up there, now high range not doing so good up hills though...lool
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
BESTWAY AG VSK50 LOT IDENTIFIER 95 (A53084)
BESTWAY AG VSK50...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
2002 CATERPILLAR 973C CRAWLER LOADER (A51246)
2002 CATERPILLAR...
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
