J D,A oil filter bolt stripped
   / J D,A oil filter bolt stripped #1
HNSTABE
Plain City, OH
Kubota L285
A AAany ideas on how to fix this?
   / J D,A oil filter bolt stripped #2
Is it the bolt threads or the internal threads on the tractor?
If it's the bolt you can take it to a machine shop and have them weld it and rethread it.
If it's the threads on the tractor the only option is a thread insert or helicoil which is going to be tough since it's so far to the threads from the bottom of the tractor.
I haven't been able to get it off.
   / J D,A oil filter bolt stripped #4
Is the head rounded off? If so weld a piece of flat metal to it so you can get a wrench on it, or pipe wrench.
   / J D,A oil filter bolt stripped #5
Is stud(key 19) the part that's stripped? It appears to be replaceable but one needs tractor serial number for correct part.
   / J D,A oil filter bolt stripped #6
The neighbor was working on a old Deere and had to pull the crankshaft because it had a knock. After the work was done, they found out the oil filter bolt was over tightened and damaged the oil pump which probably caused the knock. It sounded like it was a major job fixing the pump too.
The bolt head is in good shape. it just turns but will not come out.
   / J D,A oil filter bolt stripped #8
Is the filter cover loose or is it stuck to the gasket holding it in place? It may not be stripped, it could just be stuck.
Over time those gaskets get hard as a rock and can be a bear to get the cover off.
   / J D,A oil filter bolt stripped #9
Any updates on this? What did you find out?
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
Diesel Fuel Tank And Pump (A51691)
Diesel Fuel Tank...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
