J D 425 Problem Starting 20HP Kawasaki
   / J D 425 Problem Starting 20HP Kawasaki #1
stu1951
Goderich,Ontario. CANADA
BX2350
I am having problems in starting my 425
Everything is clean! New spark module.
It will flood very easily. Usually starts if not using choke and throttle on lowest. If it doesnt start right away......I must leave it and try again later. If I use throttle and choke on inital start it makes it worse and will flood out very quickly. When it is running it works fine.
Thanks or your help!
   / J D 425 Problem Starting 20HP Kawasaki #2
Have you adjusted the float?
Seems the float is allowing in too high a fuel level in the carb.
   / J D 425 Problem Starting 20HP Kawasaki #3
Do you have spark at the plugs when it won't start?
I just went through this on my 425, and it was the time delay relay.
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2015 Chevrolet Impala (A55758)
2015 Chevrolet...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
(APPROX 15) 6" X 2" X 68" TUBING (A54756)
(APPROX 15) 6" X...
