J D 425 Problem Starting 20HP Kawasaki
   / J D 425 Problem Starting 20HP Kawasaki #1
stu1951
Goderich,Ontario. CANADA
BX2350
I am having problems in starting my 425
Everything is clean! New spark module.
It will flood very easily. Usually starts if not using choke and throttle on lowest. If it doesnt start right away......I must leave it and try again later. If I use throttle and choke on inital start it makes it worse and will flood out very quickly. When it is running it works fine.
Thanks or your help!
   / J D 425 Problem Starting 20HP Kawasaki #2
Have you adjusted the float?
Seems the float is allowing in too high a fuel level in the carb.
   / J D 425 Problem Starting 20HP Kawasaki #3
Do you have spark at the plugs when it won't start?
I just went through this on my 425, and it was the time delay relay.
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
UNUSED LANDHONOR 3.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2018 INTERNATIONAL 4300 BOX VAN (A54313)
2018 INTERNATIONAL...
