J-D 1010
/ J-D 1010 #1
Anonymous Poster
Epic Contributor
What is this tractor worth? It has 440 hours, gas, fair tires, runs good needs TLC and has a rough J-D Rotary cutter with it.
Thanks in advance.
/ J-D 1010 #2
Value varies too much by location for me to make an educated guess, but I will say that the 1010 is NOT one of JD's more popular offerings. It has a nasty history of engine problems.
/ J-D 1010 #4
You don't say if you are buying or selling. If selling, its worth probably more to you (you have more invested) than what you can ask or get for it.
If you are buying, its worth is based on what you want it for, what you might have to invest in it after you find out what is likely wrong with it (truth is someone wants to get rid of it for a reason), and how much of a risk you are willing to take.
I looked for years for a JD 1010. It was the first 4 cyl JD came out with, and it was in the body of the time-tested MT, 40, 420, 430 series of the 50's. Good 3pt, good tranny, good workhorse of a utility size tractor (I had a 420 for years). I would probably figure one would be worth about $3500, give or take $1k for condition and desire to keep it running. I sold my 420 two-cyl for $5900 two years ago. The 1010 isn't the vintage material that the 2-cyl is, IMO.
/ J-D 1010 #5
Didn't the JD1010 offer gas and diesel??
Start on gas than swtich to diesel??
/ J-D 1010 #6
If I recall correctly, the gas engine was prone to premature sleeve wear and requireing major overhauls in about half the hours of other engines of similar horsepower.
Don't recall hearing anything particularly bad about the diesels.
/ J-D 1010 #7
I don't believe so, Thomas, but I could be wrong. Pretty sure the diesel they offered was a straight diesel start and run.
/ J-D 1010
I may be interested in this tractor. Please call me at 5179372057.
/ J-D 1010 #10
I agree with pfoxy, I think that the diesel 1010's started on diesel and stayed on diesel. Some of the old Farmalls, though, did do it the way you described. They had all the parts to run it on gas (magneto, spark plugs, etc.), but also an injection pump and injectors for diesel so that once it started, you switched it over. And of course lots of the old two-cylinder deere diesels (and many others such as vintage Cats) used small, seperate, gas-fired "pony motors" that not only cranked the main diesel engine but also warmed it up beforehand (from the engine and exhaust heat). Though it sounds crude, this system worked quite well, much better than early electric start systems (which became available on Deere diesels in the second part of the fifties).
/ J-D 1010 #11
Love them "pony start" Deeres. I'd give my left, um.... "appendage" for an 820 or 830 pup start. The later electric direct starts were okay once they got the system figured out, and they eliminated the maintenance on the pony engine. Dang near as expensive to rebuild a pony engine as it is to rebuild the main.../w3tcompact/icons/frown.gif
Electric start is not nearly as manly as the pony tho /w3tcompact/icons/smile.gif
/ J-D 1010 #12
Yeah, maintenance was one of the drawbacks of the pony. And yeah, once they did some work on electric start (as well as made diesel engines themselves easier starting) it was the way to go. I doubt anyone nowdays wishes they had a pony on their new Deere! But at the time they were probably the best answer, and darn cool to boot! Of course they weren't designed to last like the rest of the tractor, and nowdays it's hard to find a good one and harder to find parts to fix a not so good one. I have heard of someone adapting a Briggs (or something) in place of the pony on an old diesel (I think it was on a 70, but I'm not sure). I haven't actually seen it, though.
P.S. I agree that the 820/830 rank near the top of my list of coolest tractors ever!
/ J-D 1010
I haven't gotten an email from you yet. Please call back, I am interested.
/ J-D 1010 #15
Ob1, you got to be registered to post pics.
/ J-D 1010
I meant for a regular old email. AOL doesn't like me to be online for very long without booting me off!
3142 (A63117)
3142 (A63117)
2017 VOLVO SD115B PADFOOT ROLLER (A65056)
2017 VOLVO SD115B...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2005 Ford F-450 Crane Service Truck (A66736)
2005 Ford F-450...
