ivt transmission low oil pressure
   / ivt transmission low oil pressure #1
bblawn
newport,vt
6420 IVT
hi I changed my trans ivt in 2009 oct and this week it wouldnt move forward or backward JD tech check the trans filter and with the code TCU 304177 304079 witch is low amperage and low oil pressure. he found it grainey abit and I had just changed both filters for hydralics. from the oil change the tractor ran only two hours. (maybe i should of left the old oil in!) The tech said it might be the pump because he had no pressure reading at the transmission.
Now, JD doesnt serice an IVT trans but might chage the pump. They havnt done it , so I called 3 other JD s and got the same respone A new trans cost $25000 plus core -$5000 maybe and labor. they quoted a new pump at about $4000 plus 14 hours labor.
   / ivt transmission low oil pressure #2
Suggest a Moderator move this to the John Deere AG tractors
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
