I've got a 140 3 point lift NO REAR HYDRO Outlets - so I put it on the front of a 318
   / I've got a 140 3 point lift NO REAR HYDRO Outlets - so I put it on the front of a 318 #1
shadetree
I'm not in mid-life crises way too late for that, but there are many things that I've been meaning to do that if I don't get to it they aren't going to get done. I'm going to try and forget about the things that I used to be able to do and can't any more and do as much as I can of what I can. My life hasn't turned out like I thought it would, well let's skip that cause I can't change it now. When I first saw a 140, I wanted one. Couldn't afford it. Never was able to outgrow that in real time but I got a 140 a couple of years ago. Haven't gotten it running yet... Well when I first saw a 318 - you get the idea. I've managed to get several none of which were running. I've repowered because I need more bang for the buck and had not the knowledge or skill to rebuild. I do have one 318 with an Onan but that needs a carb cleaning.
To cut to the chase for now, I needed something that could move stuff around. Remember I still don't have the means to support the things I want, so I have learned to make do with what I have for the most part. I put a 3 point lift on a 318. I had a 'HF pickup truck crane' that I mounted on a draw bar. Hooked that to a machine I wanted to move and managed to lift the front wheels of the 318. Piled as much weight on the front as I could but needed more. Disgusted I was going into the house and walked by my 140 which had a 3 point lift laying in front of it that I had never installed because it wasn't running and had no rear ports. I stopped and looked at it and that little (15 watt) light went off in my head ( I bet that will fit on the front of that 318). You know what happened when I got it over to the front of the 318 - close but no go. As always being too stupid to know I couldn't do something I set about making it fit. :)
   / I've got a 140 3 point lift NO REAR HYDRO Outlets - so I put it on the front of a 318 #2
I saw that build over in the other room. Nice job.
   / I've got a 140 3 point lift NO REAR HYDRO Outlets - so I put it on the front of a 318 #3
Shadetree
I read through the post, now think you need to show us what and where you are at.
This is with a 420 mower deck - somewhere north of 300 pounds. I really want to get an AlZ LoadLifter I really like having the load out front where I can see what's going on. Turning my head...
   / I've got a 140 3 point lift NO REAR HYDRO Outlets - so I put it on the front of a 318 #5
Whatttttt???? :)
   / I've got a 140 3 point lift NO REAR HYDRO Outlets - so I put it on the front of a 318 #6
Have you thought about replacing that top link that you are using to hold the boom up with a hydraulic cylinder and hook it up to the other spool on the 318?
Yes, the jack that was on there quit working so I stuck the top link on. The link is a couple of inches longer than the jack but is rusted and hasn't broken loose yet so I can open it more. I am looking more height. Soon as I can find a hundred bucks I've got my eye on a cylinder at the Surplus Center.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2015 Caterpillar 299D2 XHP Compact Track Loader Skid Steer (A50322)
2015 Caterpillar...
8' 3 pt Disk (A50515)
Land Honor Quick Attach Articulating Boom Mower (A50514)
Land Honor Quick...
Land Honor Quick Attach 72" Skid Steer Rock Bucket (A50515)
Land Honor Quick...
