I've Been Unfaithful
   / I've Been Unfaithful #11
Re: I\'ve Been Unfaithful
I pull my M4900 on a 16 foot trailer bumper pull with my hog or the 8 foot disk but it is 6' 9'' wide inside 8 foot wide outside if this helps
</font><font color="blue" class="small">( I pull my M4900 on a 16 foot trailer bumper pull with my hog or the 8 foot disk but it is 6' 9'' wide inside 8 foot wide outside if this helps )</font>
Yardman1,
What is the GVW of your trailer? How much weight are you putting on it? Thanks
   / I've Been Unfaithful #13
the Trailer is rated 14,000 lb the M4900 is about 4000 lb so i put about 7000 lb on it but some times a lot more it pulls very good but you need a full size truck to pull it i have had the trailer for 10 years and have pulled the kubota 5 years I hope this helps
Yardman1,
Thanks for the info. If I move up to an M6800 or M9000 I will probably go back to a 14,000 gvw gooseneck to be safe. I have recently seen a gooseneck with a tilt bed deck (see picture attached) and a gooseneck with a hydraulic beavertail that once you drive up on the tail it can raise the tractor up and become flat with the rest of the deck. What will they think of next?
/forums/images/graemlins/confused.gif
   / I've Been Unfaithful #15
Nice picture and i do like it but does it come with Dual Wheels for it would be even safer when you have a flat. if it does have Duals let us know.
</font><font color="blue" class="small">( Nice picture and i do like it but does it come with Dual Wheels for it would be even safer when you have a flat. if it does have Duals let us know.
)</font>
The one I saw didn't have duals. You are right about the advantage of duals if you get a flat tire. Before I consider buying a new trailer I'll wait until next Spring when I start poking around for another tractor to put on it. /forums/images/graemlins/grin.gif
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2008 Blue Bird School Bus (RUNS)(TITLE) (A50774)
2008 Blue Bird...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
Rhino FL15 (A50121)
Rhino FL15 (A50121)
